Here's the deal, about ten days ago I started my car to do some carb work, and it started without incident as always. I warmed it up and just as I was about to start working on it, my wife came home and needed a hand. I shut off the car but left the keys in the ignition (turned off).
Never got back to the car and forgot I had left the keys in the ignition. Yesterday, I went out to work on the carbs and it starts, but as soon as I let the key go it dies.
It's a 70 914-6 2.0T with E P&C, Bosch distributor 7100 RPM redline (no vacuum advance), Permatune ignition (installed back in 1987), Webers. Timing around 5 degrees BTDC and 35 degrees full advance.
What I have tried:
replaced the points and set the dwell
swapped the coil
changed the plugs
Replaced the filters
I've got fuel
I've got spark
Checked fuses
I pulled the wire cap off the back of the ignition switch and hooked it up to a spare switch - and still same results?
Could I have damaged the Permatune by just leaving the keys in it?? What am I missing here??
Thanks,
Justin
