kbrunk1
Oct 6 2012, 05:33 PM
Was cleaning up and found the two copper washers that go under the two lines from the brake fluid holding tank.
How bad did I screw up?
I do not believe this is on the pressure side of the master cylinder.
Thanks
Oct 6 2012, 06:15 PM
It's your brakes. Do it right.
okieflyr
Oct 6 2012, 06:30 PM
Did you use new washers on the banjo pressure fittings? There should be some there on the top and bottom of the fittings. The feed lines are a tight slip fit into the rubber grommits on top of the master cylinder.
DBCooper
Oct 6 2012, 07:24 PM
Yeah, I don't think there are washers in the feed line, no pressure, no need for them. Copper is for crush washers, for metal fittings.
Cap'n Krusty
Oct 7 2012, 09:16 AM
Well, there ARE washers in the fluid inlets, and you should put them in there.
The Cap'n
