Harpo
Oct 7 2012, 12:31 PM
Below are my dimensions for the rod journals
Main------- rod rod main rod rod main
59.76 49.86 49.68 59.68 49.72 49.71 59.69
59.81 49.84 50.81 59.68 49.78 49.71 59.70
59.70 49.70 49.77 59.78 49.83 49.82 59.74
59.70 49.69 49.73 59.66 49.72 49.71 59.66
What size bearings do I need? The condition of the journal seems really good and the previous owner though it was polished.
Thanks
DAvid
VaccaRabite
Oct 7 2012, 05:46 PM
If you are asking this question, this is something you should get a machinist to help you with.
Harpo
Oct 7 2012, 06:32 PM
Yes I will also be covering this with a local machine shop but I have never done busines with them before. I just want to be a knowledgable consumer.
Thanks
David
Valy
Oct 7 2012, 10:26 PM
Your readings are not consistent so it's either that you're not measuring well or the crank needs to be ground.
The bearings come in 0.25mm increments on the crank side.
You also missed the case size measurement that is very important when choosing the bearings. On this measurement, the steps are STD or +0.5mm. The middle split bearing is the most abused.
rhodyguy
Oct 9 2012, 09:27 AM
if the case has been or will need to be align bored you'll need the appropriate over size ones.
Cap'n Krusty
Oct 9 2012, 09:30 AM
If you're not messing with the bore and just polishing the crankshaft, read the numbers off the old bearings and order the same ones.
The Cap'n
