Allan
Oct 30 2004, 04:21 PM
Don't have my haynes manual with me but I'm guessing that this is the throttle position sensor. Is it okay to pull it off so I can clean up the throttle body? Will it be a PITA to put back and readjust. Thanks
Allan
Oct 30 2004, 04:22 PM
OOPS!!
Mueller
Oct 30 2004, 04:37 PM
yep....TPS...do a search here, Dave Darling (?) posted a diagram or a link on how to adjust one
Rhodes71/914
Oct 30 2004, 04:38 PM
Yes that is the TPS. Open it up and look at the contacts. Mine was worn bad and putting a nwe one on made a huge difference. As far as setting it correctly banders djet site or pelican can remember which one, has easy instructions if you have a multimeter. If not and it was working properly when you took it off you could just line it up where is was before you took it off.
Allan
Oct 30 2004, 09:40 PM
Thanks.. Any suprizes pulling it off (springs flying out, small parts falling out, etc.)/
Rhodes71/914
Oct 30 2004, 10:18 PM
No surprises pulling it off the shaft coming out of the throttle body. May take a little force, mine was stuck on pretty good.
Allan
Oct 31 2004, 09:20 AM
Thanks, I think I'll mark it and try putting it back in the same position and see how that works.
Bleyseng
Oct 31 2004, 10:30 AM
If you are taking it off then adjust it with a DVM afterwards , pretty easy to do.
