Rusty
Oct 31 2004, 03:30 PM
Rich suggested that to ensure you have the correct "feel", that you use a micrometer to set a gap, then run the feeler gauge through it. I grabbed my new digital (mechanical) micrometer and tried that.. and felt a moderate amount of drag on the feeler gauge.
Then, after having oil dripped on me while taking off the valve covers... I had a thought.
I dipped the feeler gauge in a bit of oil and wiped off the excess, leaving only a film. Then, I tried to slide it into the micrometer. Wow, that's tight! Maybe I've been setting valves too loose.
Oh, and I spent a long time cataloging all the potential "while I'm under there" stuff. I found a bit of rust to squash this winter, and more oil leaks than I'd care to think about.
-Rusty
TheCabinetmaker
Oct 31 2004, 03:40 PM
Rusty, I've neer done a six, but a feeler gauge is a feeler gauge, so here goes. When I started adjusting my own valves, they would still clatter. I was indeed setting them too loose. If you have .004 gap, a .004 feeler should be very tight, and a .005 should not fit period. If it does, it's too loose.
Sammy
Oct 31 2004, 05:39 PM
I agree, I like to set them at a tight four, or very loose three. If you set them at a loose 4 they might clatter a little tiny bit.
I personally like using a dial indicator because the feeler gauge I have really doesn't work that well, kind of a PITA.
With the indicator I just stick it on there and measure, if it's still good I move onto the next one. saves time. If they are all good I can do it in 20 minutes.
With the feeler guage I have to loosen every one up to get the feeler gauge in and then set them.
I don't know if a dial indicator would fit in a 914/6 tho.
Bruce Allert
Oct 31 2004, 06:29 PM
OK, so... how do you know if it's too tight or too loose? I've been getting a wee bit of clatter everytime. I'm always afraid to set them too tight. Is there a way to explaine the "good feel" of the sliding of the gauge between?
Also, your mentioning of the .004 & .003 adjustments... is this for the 6 & not 2.0 or 1.7?
...b
Bleyseng
Oct 31 2004, 06:33 PM
.006 is for a 2.0l FOUR banger although the exhaust valves if stock sodium filled are .008. I run mine at .005 for AXing.
Geoff
Bruce Allert
Oct 31 2004, 06:37 PM
Ya, that's what I've been setting them at.
Which ones are you setting at .005? Int. or Ex?
....b
TheCabinetmaker
Oct 31 2004, 06:48 PM
Bruce, the "feel" is hard to explain. Tighten the adjuster so you can't pull the gauge out. Back it off till it just comes out with a little force. It should "feel" hard to get the gauge in and out. I doubt that we could move the spring with a .005 feller gauge. If the next bigger gauge won't go in, then you are there. If it does, then you are loose.
I set mine at a tight .005 (2.0/4). I've found that .006 works fine for a 1.7
Be faithful with the mileage, as they have a tendency to tighten after time, not loosen. I use a liberal amount of wheel bearing grease on both sides of the cover gasket. helps to seal and makes it slide right off the next time. I can even reuse them once with no problem, but always keep a few extra sets on hand just in case.
Bruce Allert
Oct 31 2004, 07:42 PM
QUOTE(vsg914 @ Oct 31 2004, 05:48 PM)
Curt, are you setting both intake & exhaust at .005 on the 2.0 or just the intake?
.....b
TheCabinetmaker
Oct 31 2004, 07:45 PM
Both.
tod914
Oct 31 2004, 09:45 PM
...it should feel like pulling a piece of paper from inside a closed book
We talking War and Peace or Green Eggs and Ham?
J P Stein
Oct 31 2004, 11:54 PM
It's .004, +/-.001 so don't get all anal about it. <_<
I do the .004 goes, .005 don't.....close enuff......but I've been
setting valve lash for more years than I kin remember. Just make sure the jamb nut is tight and check again after it's tightened.
IronHillRestorations
Nov 1 2004, 08:32 AM
Pat Williams in Memphis (a excellent 911 engine builder) set me straight on valve clearance. I made the comment that "a little loose is probably better than a little tight". If the valves are a little loose then you aren't getting total lift. Yes there is a "range" but dead on the nuts is always preferred. I get the correct feeler gauge to drag (like Martin says) and make sure the next size up won't fit. So it may take a little longer, but 6K miles doesn't come around too often.
DonTraver
Nov 1 2004, 10:14 AM
A dial indicator will work on a 6. The indicator holder is the key. I modified this one to work. Works great on my 914-6 2.0L and my 3.6 L RS America. This picture is the 3.6 L last weekend. Good luck.
Bruce Allert
Nov 1 2004, 07:26 PM
QUOTE(J P Stein @ Oct 31 2004, 10:54 PM)
and that brings up another question
How tight is tight? do ya torque it or just a WAG?
I've been using a 6" ratchet with a socket to do the final crank down... not too hard but enough to what I think it won't come loose.
......b
TheCabinetmaker
Nov 1 2004, 07:51 PM
QUOTE(Bruce Allert @ Nov 1 2004, 07:26 PM)
......b
Bruce, you nailed it!!!!!!
GS9146Driver
Nov 1 2004, 08:35 PM
All this talk of valve lash adj. has inspired me, I think I will go get with it and adj. the 914-6. I'll have to try the dial indicator, nice idea.
Thx, George.
ArtechnikA
Nov 1 2004, 08:37 PM
just for completeness / correctness --
0.004" == 0,1mm -- NOT 0,01mm ...
Rusty
Nov 1 2004, 10:20 PM
Corrected, Rich. Thanks.
