In the mornings, my 914 is next to impossible to get running (2.0 D-jet)
After several minutes of trying, I can usually get it started to where it will keep running after many attempts where it will barely idle and pumping the gas pedal either does nothing or kills it. Once running, it is rough.
Now here is the odd thing... I can leave it for 15 minutes or so and then go back and it fires right up. Somewhat rough as I drive down the road but after a mile or so things clear up and it runs great.
My question: is there a part of the FI system that, if not working properly when the engine is "cold", will work normally once the engine has warmed up some? What do I need to check? The ambient temp is not exactly cold and the same issue happens after the car has been off for a couple hours or so even if it has been sitting in the sun.
Or is there something else I should check?
thanks!
