Zeke
May 14 2003, 01:55 PM
I am preparing to install a head temp sensor from VDO. Does one like to run hotter than the rest like a Type I? Even a little bit?
john rogers
May 14 2003, 02:26 PM
Milt, on my race car we found #2 ran slightly hotter than the others by pyrometer reading. It was also the cylinder we kept breaking valve on. I have the 911 fan set so I think the front cylinders get slightly less air than the rear. Good luck.
StratPlayer
May 14 2003, 03:57 PM
Have a 76 2.0 Djet, I have my vdo CHT hooked up to the 3rd cylinder.
ChrisReale
May 14 2003, 04:42 PM
Zeke, you probably already know this, but the stock location is on the third cyl. If you have a pyrometer, drive the car around and see if there is a cylinder that runs hotter than the others. Maybe place it there...??
Aaron Cox
May 14 2003, 05:28 PM
can you hook up the cht sensor to the combo gauge?
like use the oil temp module for the cht?
Zeke
May 14 2003, 05:31 PM
I don't thiiiiinnnk so. The CHT guage goes to 600*
Ouch! Anyway, guages and sensors are a matched pair from what I know.
StratPlayer
May 14 2003, 05:34 PM
You might be able to do that,, instead of using an oil temp gauge use a cht gauge using this guys method, the gauges are the same size. Just might work, just 2 wires coming from the gauge itself.
http://www.914world.com/bbs2/index.php?act...=1784&hl=gauges
Aaron Cox
well, what about the non numbered oil temp module?
calibrate it for the gauge?
