I have a 180 degree MOCAL oil thermostat correctly installed near the engine for my 12" x 12" front mounted oil cooler. The cooler does a fantastic job of keeping oil temps just above 180 even on the hottest track days.
The problem is driving around town. The oil temp will not go higher than 135 even after driving for an hour. I blocked off the intake to the cooler this morning and managed to get it up to 150, but no further. Ambient air temp this morning was about 55 deg F.
I understand that the thermostat will bypass some even when cold, but it seems to me that it is bypassing a lot more. Just curious what others have seen in their experience.
I'm close to putting a small damper and actuator that would control when the cooler gets full flow based on an existing on/off switch I have on the engine that closes at 180 deg.
