2.5" plastic pipe end cap Cut off 18mm Thin down 1-2mm Paint
Fits rear perfectly
Will have to thin a little more on fronts. Will do those next weekend.
$2.25.
76-914
Oct 23 2012, 12:29 PM
Just to clarify. They don't make PVC or ABS in 2 1/2". I'll bet your referring to 2". 2" pipe measures 2 1/2" od
bandjoey
Oct 23 2012, 01:27 PM
Yep. Box said 2.5
Mike Bellis
Oct 23 2012, 01:46 PM
QUOTE(76-914 @ Oct 23 2012, 11:29 AM)
They do make and is available from a plumbing wholsaler. HD may not carry this size in all locations.
76-914
Oct 23 2012, 03:35 PM
They do make (in plumbing) 2 1/2" PVC for pressure pipe (type 1), but not in the DWV or type ll. Nor is it available in ABS, anywhere. 2 1/2" is seldom used because it is cheaper to run 3" and reduce when/where necessary. That sure looks like a "2" stamped on top of that fitting. But then again I'm sitting in the dentists chair using the iphone and probably slightly modified.
bandjoey
Oct 23 2012, 06:49 PM
Cheap and ur right. 2" pipe for the plumber and something bigger on the outside. Didn't take much off and it fit perfectly.
Now should I get the eBay plastic center cap Porsche stick on decals ?? Or s that too much pimp??
69telecaster
Oct 24 2012, 10:51 AM
QUOTE(bandjoey @ Oct 23 2012, 08:49 PM)
What holds them in?
bandjoey
Oct 24 2012, 04:03 PM
Squeeze fit just like the originals. They're about 1-2 mm snug fit with a mallet.
