I have posted about this before, but I have more information that may allow some of the gurus here to solve the problem.
The bottom line: HP is way below what it should be. I am getting on the dyno 106hp at the wheels.
The motor:
2.7 liter flat 6.
Headers
Modified E-Cam for carbs.
CIS runners and throttle body with Megasquirt EFI. (Tuned on the dyno.)
Pertronix ignition and multispark second strike controller
Mahle euro pistons and cylinders
I checked the compression and its right around 160 within 5%.
I checked the timing, at idle and all in at 5,000. (Kind of un-nerving to check.)
Spark is strong. New plugs.
Ok. Here's the new bit:
I ran an autocross this weekend. The engine was around 160 F at the start of the runs. The first and second run, the car missed and backfired right around 5,000 RPM.
On the third run, the miss completely went away. Same on the third run. My co-driver drove 4 straight runs and no problems. I even did a 0 to 60+ run all the way to redline without a single miss.
So, what was different? The engine temperature at the third run, cleared 180 F and stabilized around 190 F.
Ok, what could be causing this? I have the cold start on the MS set to 90 F as I had problems with correct sensing of
"warm running". I used the laptop to make sure when the temp was 160+ the engine was not in cold running mode.
So, would hotter plugs help? Why would the temperature have this effect?
Thoughts?
This is driving me nuts, as the car is doing well. The coil-over front suspension is working great!
-- brett
