QUOTE(Kirmizi @ Oct 25 2012, 04:01 PM)
Where is it leaking/dripping from? Same place as before the repairs?
You may need to let it run awhile to allow some of the residual oil to drip or burn off.
Mike
Yes , it seems to be in the same area. I get most of the oil with rags and paper towels, so I'm sure it's not residual. I don't think I overtightened the oilcooler seals. Plus I get up and look at the pressure switch, It was difinitely leaking before and can't see any oil at all there.Do oil coolers leak? or mostly just the seals?I guess I could try to tighten the oil cooler a little bit more, but I read not to tighten too much.
