Making the bends in the front of the tunnel is the tough part.
I recently replaced the leaky stock fuel lines on my -6. This was a piece of cake with the engine/tranny out of the car. Don't know if this is possible with the engine still in, but I made the 45 degree bends at the gas tank ends before I put the tubing into the tunnel. I then snaked the tubing past wiring and brake lines and out of the two holes in the front of the tunnel. I angled the front of the tubing the way I wanted it and then marked an X on the back end of the tubing on the side where I needed the right angle bend in the engine compartment. I withdrew the tubing just enough to get a pipe bender on it and bent the 90 degree bends. I re inserted the tubes all the way in and put the grommets on both ends (lube up the grommets with glycerin). It was easier than I expected, but like I said the engine was out of the car.
