I've never had more fun driving a car. This is my second 914. It's garage kept and was my daily driver for 4-5 years until I had the engine rebuilt and mechanics serviced. I bought another car for my 60 mile round trip drive to work so I wouldn't rack up miles on the 914 after all the work I had done to it. I only drove it for about 100 miles after that. It's been sitting pretty in my garage undriven/unstarted now for almost 5 years because when I moved into my house and bought another car, my financial prioritizes went towards my home instead of owning and maintaining two cars, this one being a second/leisure vehicle. It needs a good home to someone who will enjoy it and of course, drive it!
- ORIGINAL PAINT COLOR: SCARLET RED (Porsche color code L31M)
- EVERY ORIGINAL FACTORY OPTION INCLUDED:
- Rear Window Defroster
- Full Center Console with Gauges
- Leather Wrapped Steering Wheel
- Leather Shift Boot
- Dual Horns (currently disconnected)
- Loop Carpeting
- Middle Seat / Armrest
- Center Storage Box
- Fog Lights
Mechanical work done by a well-known experienced local Porsche mechanic and 914 authority ("Chief" at Pistons and Rotors) and local 914 guru "Dr." Phil (the Porsche doctor) who has owned 18 914s and restored most:
- Engine thoroughly cleaned inside and completely rebuilt with OEM parts inc. heads, pistons, valves, gaskets, etc.
- Added larger jugs to engine for more horsepower.
- Original fuel injection rebuilt
- New air flow meter for fuel injection.
- Transmission serviced.
- New distributor.
- New fuel pump.
- Installed hot start (eliminates need for points)
- Interior is in very nice shape.
- Center console with all gauges (volt, oil temp, clock) in BEAUTIFUL condition.
- All knobs in dash work and are in excellent shape.
- Dash back in great shape. Front dash has cover.
- Original leather wrapped steering wheel.
- Factory carpet in great shape.
- Original speaker grills.
- Back pad in excellent shape.
- Seats in good shape. They have a couple rips in the side that can easily be mended or have recovered.
- Pop-up headlamps and factory option fog lights all work and in great condition.
- Pop-up headlamp motors replaced.
- Daytime running lenses, harder to find American tail lights (all red) and side markers all in great condition.
- Targa hard top in excellent shape, no scratches, fading, etc. Still has original carpeting underneath.
- Original factory wheels plus spare wheel.
- Brand new BF Goodrich G-Force tires.
- Front and rear bumpers are in excellent shape.
- Original side mirror in great shape.
- Engine grille in great shape.
- Larger (front) calipers on rear (means no emergency brake).
I have receipt documentation for the following new/rebuilt parts and restoration services and where they were performed:
Overby's, Inc. Jacksonville, FL
- Fuel injection serviced
- Replaced headlight switch
- Tune up
Automobile Atlanta (914 specialists), Marletta, GA
- Floor pan patch and coat, install pan tar and heat
- Carpets replaced with OEM 914 factory carpets (not aftermarket)
- Rear window installment kit and re-sealed
- R&R steering column and install new ignition switch assembly
- Install dash cover
- R&R temperature senders and replace Oring
Chief's Pistons and Rotors, Inc. Jacksonville, FL (Porsche and VW specialists)
- Replace starter
- Install new oil cooler
- Fuel Injection serviced
- Rebuilt engine with stock parts
- New bearings
- New crank shaft
- New push rods
- New gasket kit
- New spark plugs
- New fan belt
- New front and rear seals
- Rebuilt engine heads
- Install new engine valves
- New speedometer cable
- New motor mounts
- Replaced fly wheel
- Replaced fan
- New larger oil cooler, cooler adapters, fittings, liners
- New set of shifter bushings
- New air filter
- Replaced ignition coil
- Replaced fuel pressure regulator
- New fuel pump
- Repainted wire harness to dual fuel relay
- Cleaned all grounds to maintain harness under circuit block and relays
This is a solid, car, solid body, very nice and was a great daily driver. Floor pans are clean and solid. There's only a few minor cosmetic flaws that are easily repaired. Rear engine lid needs one new arm bracket or existing can be re-welded. The original paint color is Scarlet Red (Code L31M). Previous owner had it repainted the same, original color. Paint is good shape save a few tiny nicks from road debris and small area of chipped paint on hood. I always got compliments on it and kept it very clean and garaged. Original spare wheel included. The only aftermarket body parts are the rocker panels (has attractive raised PORSCHE lettering along side) and the rear trunk "Porsche" reflector which never came on the 914 and will be sold separately. Also, as an added bonus, I have the very nice all-chrome luggage rack that was commonly installed on the 914. It came in very handy to a few trips to the airport. If wanted, I'll include it in the sale for a small fee. Otherwise will sell separately (luggage rack not pictured but will provide picture upon request). Car has been in my garage and hasn't been driven or started in 5 years, so it will require a fresh tune-up (replace gas, oil, etc. to lubricate the system). Car ran fine and was my daily driver for 5 years before stopped driving.
THIS IS A VERY NICE 914! PRICED TO SELL OR BEST OFFER! Contact me for more info/offers
Asking $10K or Best Offer.
I have lots more pics if wanted.
Email: tuma_milhem@yahoo.com
Call: 904-737-0287
