Updated 11/8/12 with some lowered pricing and sold items deleted.
I ship after paypal in USPS sizing $5, $11 and $15 bucks, so add that to the part or parts you want. If there is a dimension problem, no problem, I will go to a larger flat rate box.
[u]IF IT IS OFF THE LIST BELOW THE EACH OF THE PICTURES, THE ITEM IS SOLD AND GONE.
[u]
Thanks!
John
914 901 speedo drive - $60 - with new o ring
911 901 speedo drive - WORKS IN OPPOSITE DIRECTION OF 914 Speedo - BE CAREFUL - Will NOT drive 914 speedo - BRASS - Rare - $90 with new o ring
914 Gas pedal rod - $10
914 Trip Reset shaft - $10
6 working OEM relays - $50 for all 6 - Will sell in groups of 3
Mahle 2.0L Euro 8:1 OEM NOS piston set - $914
GA0009774 Split case bead blasted and NEW studs all around, even have a bag of 2 new small studs not installed. This is a nice case. Small nick near the oil front seal was determined by Image Imports not to be of any consequence - Needs .020 line bore - $300 - I can get it done but I would need to get prices from Fat and Rimco for you. FAT also has oversize main bearing sets that they could fit for you. Line boring and fitting prices I can get for you before it ships, and you can pay me to pay FAT or Rimco. I have experience with FAT, and they are great! Hard to find a real 74 2.0L case that is dimensionally correct. Ask Bruce Stone if you have doubts.
Good 2.0L crank and cam to go with the Split Case - Crank $125 - Cam - $50 - From the Bruce Stone collection - Cleaned in the hot bath tank and all journals and camlobes being checked by Image Imports on Friday. Wait 2 days and I will confirm sizings.
1 sets of 914 front brake pads - $15 per set of 4 - They are 1975 NOS Asbestos supergrippy ones, but they take time to brake in correctly, and they can glaze easily and 1 set of NOS Ferodo Formula 2 Asbestos from 1979 - $25
2 redone crispy headlight buckets - Grey painted - $60
914 2.0L Redone front brakes - Used them for a year and replaced with a set from Eric Shea - These were redone in 2008 by Porsche Boise then sent to PO for install in Oregon. Just hotbathed and came out killer. NO MORE DIRT! $140 for the set - do NOT need redoing
1973 2.0L ECU - Make sure you know your true part number - $200 Works! Tested in Orangina in 2012. Cleaned up the case tonight by hand. Looks good.
1 Bruce Stone recoated Front brake dust shield - Absolutely no dents - $10
Oil Dipstick Temp Stick - NIB - $50
3 - 2.0L gaskets - NIB - $6 for all 3
2 - unused 2.0L FI Tubes 3 hole gaskets - $20 for both
2 aluminum engine deck rollers - $15
Radio Plate NOS with real cardboard gasket - $55
2 Aux Air Valves - Working - $25 each Money Back if not working - Tested in Orangina in June
2 Rearview2 - Large 914 OK - $25 - Large 914 good - $35
Working 3 Port pump from Jeff Bowlsby - I paid $95 - I will take $75
Triple gaugecluster Frame and 2 small crisp gaskets $25
2 914-2.0L Copper Exhaust Gaskets - I keep finding more -NIB - $5 for the pair
NOT PICTURED - 911 VDO Temp/Pressure gauge - White LED's done by the Great Al Garcia - RIP AL. You were the best in all ways, particularly LED work - $160 - Prior redo by North Hollywood Speedo before Al's LED wiring. This is crisp and rare.
Thanks!
John
avidfanjpl
