http://www.magnesium-elektron.com/about-ma...nesium.asp?ID=4"When machining magnesium, carbide tools are generally preferred when long production runs are expected. Magnesium conducts heat quickly away from the tool tip, so as long as the tool remains sharp, machining magnesium is an inherently fast process. Magnesium is normally machined dry. If coolants are necessary, then a light mineral oil should be used, rather than a water based lubricant. After machining magnesium using a water based lubricant, the storage of the resultant swarf is more difficult, due to the risk of reaction between the swarf and the water.
Magnesium components are almost impossible to ignite through the machining process, as magnesium must be heated to its melting point before it will burn. Magnesium swarf can be ignited, but the fast machining process should produce large chips which reduce this risk, as will good housekeeping practices. Cleaning machines regularly and correct storage of the resultant swarf are important aspects of machining magnesium.. "
DR Thanks for the tip on lug hole radius. since I have more than 50mm of stud protruding from the brake rotor hub and I can't get 10 turns on my lug nuts, I don't think the lug holes are radiused very deep.
I'll get some pics and measurements tonight.
I already voted so I can go the the Elliott Bay Motorsports Club Meeting and suck down a few
while talking about fast cars!
Thanks
Eddie
Anyone have a BIG metal lathe or milling machine that needs to be exercised?
