kbrunk1
Nov 2 2012, 04:31 PM
I have two questions.
1) What is the best way to put the spring clips back on valve covers.
Short screwdriver, long or 45 degree angle use muffler(not)
2) Why is there not some sort of rubber gasket instead of cork?
Is cork better? Seems like old technology to me...??
Thanks
TheCabinetmaker
Nov 2 2012, 04:51 PM
Cork better. Some gaskets have a cork/rubber mix. I don't use them unless i have to .
I put my cover in place and make sure it's setting properly, then ease the bale up as far a as I can get it by hand. My hands are not as strong as they used to be. Then I use a screwdriver to coax it home while making sure the cover does not move.
Are you not gonna ask about sealing methods?
Woody
Nov 2 2012, 05:13 PM
Glue em in place with gorilla snot.
Mikey914
Nov 3 2012, 09:25 AM
Mine are a mix of rubber and cork, slightly thicker to get more sealing pressure. Anyone want to chime in about how well they work?
tdgray
Nov 3 2012, 03:10 PM
Make sure to use RTV....lots of it....
Oh and make sure you tell the Capn when u do
Rand
Nov 3 2012, 03:14 PM
"Use muffler?"
If you mix gorilla snot with rtv and sex wax...... Well let's just say you won't fall off your board.
TheCabinetmaker
Nov 3 2012, 04:55 PM
QUOTE(Mikey914 @ Nov 3 2012, 10:25 AM)
Actually, I should clarify. I think they are all a mix. Some I have seen are mostly rubber and very little cork. They don't work very well. Mark's look to be the same composition as what i normally use. In fact, I installed my first set of Mark's on a car today. The car will be back in a couple of weeks and I'll report how they are doing.
Cevan
Nov 3 2012, 06:23 PM
I use the cheap cork ones with a little Permatex Form-a-gasket sealant between the valve cover and the gasket. Nothing between the gasket and head.
nathansnathan
Nov 5 2012, 09:06 AM
I tried the pure silicone gaskets a while ago as they say they are reusable forever, but I couldn't get them to seal even once.
Cork is the way to go, silicone or curil T to the cover, not to the head though. I just bought 30 of these gaskets from the bus depot, Elring, they were on sale from like $2 to $1 so I am all stocked with like many years' supply for $30.
