So a little background first, I started my car this weekend (for the first time in 2 years) and it seems like both injectors on the 3/4 side are not working. There is spark and injector pulse and fuel on that side. I'm sure theres fuel there because I've had leaks from loose clamps and fuel has to go through that rail to get over to the 1/2 side. Also just fyi fuel lines are all new and the tank just got boiled out and re-lined. So I assume the injectors are just a little stuck from setting and/or old gas varnish inside.
The question is will soaking them in a can of carb cleaner over night hurt the injector in any way? The yellow top is plastic I guess and I assume there are o-rings inside them.
The other issue to get opinions on is when I bleed the brakes fluid doesn't want to come out of the rear calipers. I assume its the rubber lines have colapsed on the inside and has nothing to do with the valve the fluid goes through on its way to the rear(whatever you call that valve). So what do yall think?
