freezing14
Nov 3 2004, 03:14 PM
i am finally done with the engine wiring and I am now in the process of putting all new vacuum hose , i got new hose, nice color diagram, I have all the parts but the flash back , do you have a picture can you adapt something, what about the trottl body I got 2 different 1 that has a adjusting screw on the top the other one on the side , which one is right for a 1.7 72, the number of vaccum port are different too ??? any hints
a 914 almost ready to start
SLITS
Nov 3 2004, 03:44 PM
The answer is no - send me your address, I'll send you a "flashback" valve. End of story. Pics a little later of the TB.
Joe Bob
Nov 3 2004, 03:48 PM
QUOTE(SLITS @ Nov 3 2004, 01:44 PM)
Make sure you wash it first...he uses it for an anti fart valve....
SLITS
Nov 3 2004, 04:12 PM
This is a 1.7 installed on the plenum. Butterfly cam is up and screw can be seen.
Pharting cleans it out so it works correctly!
freezing14
Nov 4 2004, 07:49 AM
thanks slits, i have e-mail you my address and thanks for the picture, 1 thiong I noticed is that the tb has a little flit tab to attached the spring, the difference between the two i have is that the other one does not have a tab the spring attache right where the throttle cable goes
thanks again
