machina
Nov 3 2004, 04:55 PM
Dr. Porsche designed them all anyway.
So I'm starting with the motor. Jake will be proud.
Next is the motor lid and the rear reflector.
sanman
Nov 3 2004, 05:00 PM
I like the covers. where did you get them? do they make dif sizes
Aaron Cox
Nov 3 2004, 05:01 PM
i have the same rainshields.
morphenspectra makes them. check the resources forum
machina
Nov 3 2004, 05:02 PM
contact nathan at: hjhl@worldnet.att.net
he had them on e-bay but I think he is a member here as well.
Aaron Cox
Nov 3 2004, 05:04 PM
are you running the CB top plate or just the f/g shields?
SLITS
Nov 3 2004, 05:09 PM
How 'bout a sticker that says, "You've just been passed by a VW"?
seanery
Nov 3 2004, 05:11 PM
how 'bout one of these on it?
machina
Nov 3 2004, 05:34 PM
QUOTE(acox914 @ Nov 3 2004, 07:04 PM)
The hats are sitting on top of the CB aluminum plates. I don't think it would seal well enough without the plates.
machina
Nov 3 2004, 05:35 PM
QUOTE(seanery @ Nov 3 2004, 07:11 PM)
that's nice,
How did you do that script? Is it a font or a graphic?
seanery
Nov 3 2004, 05:42 PM
graphic I made today. I can make these in vinyl
Aaron Cox
Nov 3 2004, 05:48 PM
QUOTE(synthesisdv @ Nov 3 2004, 04:34 PM)
you bought longer studs? also, did you use any sort of rubber dampening material?
machina
Nov 3 2004, 05:49 PM
QUOTE(acox914 @ Nov 3 2004, 07:48 PM)
Nope, they were just long enough.
You can open the filter and unscrew the long stud a couple turns. Should have enough meat on them.
Aaron Cox
Nov 3 2004, 05:58 PM
QUOTE(synthesisdv @ Nov 3 2004, 04:49 PM)
whats the thread on them? m5? m4? looks like you ditched the wingnuts
spare time toys
Nov 3 2004, 09:16 PM
QUOTE(seanery @ Nov 3 2004, 06:42 PM)
Can you make them in a gray and sized to fit the long. covers? Im thinking behind the jack point.
seanery
Nov 3 2004, 10:22 PM
Larry,
I sure can, get me a measurement and I'll let you know how much $.
I don't know if I'll be able to get an exact color match for your gray though.
