What is the best way to clean all of old permatex from the the sealing surfaces of the engine cases before re-assembly without taking away any of the metal. I don't want to create uneven areas that could lead to leaks.
Carrera916
Nov 4 2004, 11:52 AM
I usually spray a bit of carb cleaner on the edge of case to let the old glue soften up a bit.....I have a tri-blade scrapper that I always use to scrap the old glue out without shaving any metals off....maybe a couple on subborn areas
Then do it again with the carb cleaner and clean white rag to go over the edge, it should come right out...
j
URY914
Nov 4 2004, 12:02 PM
Carb cleaner is the universal cleaner.
Also scrape it with a stright blade razor.
Allan
Nov 4 2004, 03:36 PM
So stay away from brass brushes or scotch brite?
kermit
Nov 4 2004, 11:46 PM
This is basically what I did when I rebuilt my motor, but it still drips some oil.
Depending on your funds, you may want to consider line boring the cases by a machinist.
Any thoughts on this out there?
ChrisFoley
Nov 5 2004, 06:55 AM
QUOTE(Headrage @ Nov 4 2004, 04:36 PM)
I use a scotch brite disc on my air grinder after scraping all the heavy residue.
