Andy,
Here's a link to my similar 928 query post I made last Spring...
http://www.914world.com/bbs2/index.php?act...=2&t=172008.
Another area of concern of which I was made aware, is that the aluminum body parts can be hard & expensive to repair, if that's where the 82 you're considering has damage. The hood & door skins, & front fenders IIRC were made from aluminum on 928s (someone correct me if I'm wrong on where it was used).
Also FYI, another benefit of you're getting a 928, is that you can eventually use it to tow your 914-6 resto to concours events....Monterey?....see pix below.
That is - if you can get a light enough braked trailer to keep the combined towed weight below the 928's factory manual's braked trailer wt. 3527 lb limit (or 4,123 lbs according to the tag on the Porsche sold tow bar/hitch made by ORIS as OEM/OES of this part listed in the 928 PETs - see pix below). This rating applies to ANY & all 928s - no special "towing package upgrades" to suspension, AT cooler, radiator, etc. required - although the owners manuals recommend keeping your speed below 120 when towing!
... pretty awesome vehicle IMHO!
However, you'll need to get a weight distributing hitch to spread the tongue weight onto both front & rear axles, in order to keep within the 110 tongue weight limit (165 lbs. at the ORIS hitch tag pic below - note that auto mfgrs didn't publish tongue weight max. with wt. dist., but today it usually is about 2x the basic limit, & tongue wt. is usually 10-15% of the total trailer + cargo wt. fyi).
Some pix from Europe, where they used the 928s - & autos in general - more for towing, than we do here, due to less truck/suv availability & the 2-3x higher gas prices there....
Click to view attachmentClick to view attachment Click to view attachment.
And some from here in the USA....
This guy made his own hitch bar behind the rear bumper cover with the receiver thru the license plate...
And zambezi at post #4 above has a Draw-Tite hitch hiding just above his plate in similar manner & uses it to tow his other cars....
There's a guy up in WI or MN who tows his track car with his 928, which was mentioned in some of the 928 forums, but I don't have any pix of his set-up, but I think it's another 2" reciever type of "custom towbar - and not the factory removable 90-degree bent-hitch type towbaqr/hitch from the factory PET as shown in the pix below....
Another guy in Tulsa I visited & talked to back in June, who hunted down a factory tow bar for his 928 & uses it for his motorcycles....
Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment.
And this is the factory sold tow bar/hitch out of a car (download the early & late 928 PETs to see it in the parts catalog) - unfortunately long NLA, as well as a snip from the factory service manual's towing specs (note that they never retested & updated it since the initial 4.5L 230 HP V8 thru the 345 HP 5.4L with uprated brakes to larger diameter & 4 piston in 86.5 MY 1000th car on improvements....
Good Luck with your hunt!
Tom
