914GTSTI
Nov 24 2012, 09:29 PM
So, first I saw this.
Than I did this.
The front would be easy!alot of work but not hard.
But the rear?
How much of the rear end of a 914 could be removed? (Sheet metal) I think a tube end frame could be added if it would help? The sale pannels would need to go. Maybe push out the doors and the rear fenders?
How about some input!!!
scotty b
Nov 24 2012, 09:34 PM
914's lines are wrong if you want an accurate replica. IMHO It would be easier to make a ful tub frame and a fiberglass body, stick a 3.0 engine in it, and maybe use some bolts from a 914
914GTSTI
Nov 24 2012, 09:40 PM
Not to hard to see a 914?
VaccaRabite
Nov 24 2012, 09:42 PM
Tube frame a 914. Spend a on of money cutting fg body panels and you could make it.
I'd drive it. Will cost a lot to do, but what doesn't these days.
Start with a rusty tub and cut everything. Off but the vin. Go from there. Probably easier that way.
sixnotfour
Nov 24 2012, 09:46 PM
914GTSTI
Nov 24 2012, 09:53 PM
Its not to far off?
scotty b
Nov 24 2012, 10:00 PM
someone want to overlay the two pics ? 908 on top of 914, match up the frint wheels
914GTSTI
Nov 24 2012, 10:07 PM
Ok, we cant move the driver forward but???
And Its not a flat 8.
I need to go to the shop and take a long look at the 914.
914GTSTI
Nov 24 2012, 10:13 PM
I am not good with resizing! My bad!
914GTSTI
Nov 24 2012, 10:20 PM
More like this?
sixnotfour
Nov 24 2012, 10:33 PM
I believ that is the short version hillclimb 908
I think this is the longer
914GTSTI
Nov 24 2012, 10:42 PM
sixnotfour
Nov 24 2012, 11:30 PM
90.6 inch wheelbase
914GTSTI
Nov 25 2012, 05:46 PM
So I pulled some old parts and the parts car to see it a908-3/914 could be built.
Now that is some offset!!
Thats 225/50/15 with 8"x15" up front and 295/50/15 with 12"x15" in the rear.
Rear maybe to wide?
Track would be 70" front and 80" rear.
914GTSTI
Nov 26 2012, 08:04 PM
If I wanted to save the rear fenders where would you cut them out at ?
Here is a photo of the 295/50 on a 8"x15" rim with a 2" back space. The first photo was a 12"x15" with a 2" backspace. Thinking a 12"x15" with a 3 1/2" backspace is what I will try?
side by side.
And whats up with all the seam sealer?
FourBlades
Nov 26 2012, 08:41 PM
Nice project!
Ginther windshield.
John
Eric_Shea
Nov 26 2012, 09:19 PM
Someone already did it...
914GTSTI
Nov 26 2012, 10:45 PM
Thanks Eric! Photos and links would help? And then their were TWO?
Eric_Shea
Nov 26 2012, 10:48 PM
I can't remember where to find it. Truth be told, I've blocked it out of my mind. Looked like ass to me.
Silver POS somewhere here or on Pelican if I recall.
914GTSTI
Nov 26 2012, 11:18 PM
Thanks,I will go have a look.
Also I will try to not make you
914GTSTI
Nov 26 2012, 11:33 PM
This is what I found!
I will try to do better.
Ductech
Nov 27 2012, 03:03 AM
God the front end on that one looks miataish
Dave_Darling
Nov 27 2012, 09:35 AM
I think they may have used Miata sheet metal on the front? It's a LeMons car, so it may very well be a mish-mash of different pieces.
The silver one was more custom. There is a (sort of a) build thread on the Bird board. It's not to my taste, but someone put quite a bit of work into it.
--DD
Eddie914
Nov 27 2012, 02:51 PM
I like the idea.
This is the one on the Bird Board:
Nov 27 2012, 03:11 PM
QUOTE(914GTSTI @ Nov 26 2012, 09:33 PM)
- Ditch the windshield and use a short windscreen.
- Ditch the hideous roll cage and use hoops behind the seats
- Ditch the wings and make the rear end more like in the picture below
- Get a Sheridan nose and be done with it
914GTSTI
Nov 27 2012, 03:21 PM
I think the sliver one is,ok but. Its' its own look? The front is,to long? And I, could not leave the lights/hood. Pulles to much of the 914's into the look .
The door is the next problem?
Maybe that is the way I need to look at it? It will be its own look. Just more lean to the 908-3.
Ductech
Nov 27 2012, 03:59 PM
I think the best end result would be I trying to move the driver closer to the front wheels. Too long of a front end ruins it .02
brant
Nov 27 2012, 04:04 PM
barf....
ugly!
the 914 will never be a 908
buy a fiero and build a lambo
the beauty of the 908 is the driver close to the front axle and the way the body falls down toward the front of the car beginning at the front axle.
neither of those examples capture the important and beautiful traits of the 908
I think a 908 replica would be much better built on a tube frame and incorporating the beauty of the original.
914GTSTI
Nov 28 2012, 12:14 PM
Has anyone found a source for 908-3 body panels?
scotty b
Nov 28 2012, 01:04 PM
brant
Nov 28 2012, 01:35 PM
I can't imagine there is a source...
there are probably 3 or 4 of those cars in the world, and no production source.
URY914
Nov 28 2012, 02:47 PM
QUOTE(scotty b @ Nov 28 2012, 12:04 PM)
I know a shop that has the molds, but you don't have enough money.
914GTSTI
Nov 28 2012, 03:08 PM
Would still like to know what the front would go for? A wide 914 would be $2200.00. in glass.
brant
Nov 28 2012, 03:52 PM
Paul what do you think the cost would be from a real mold.
(I'm guessing 10k)
scotty b
Nov 28 2012, 05:05 PM
QUOTE(brant @ Nov 28 2012, 01:52 PM)
(I'm guessing 10k)
easily.
Buy a bunch of solid pink insulation board, glue them together and cut it to your desired shape. Cover it with a thin layer of bondo, slick it up, paint it nice and smooth, cover that with mold release, lay down some glass, pull a buck, stiffen that up, pull a mold. Viola, you have a 908 body, easy as pie.
914GTSTI
Nov 28 2012, 05:20 PM
That maybe the way I will need to go. Was hopeing their was a mold to use out their.
Maybe out of a factory mold ? $10,000?
Have a model in 1/18 scale ,guess I will need to work from that.
URY914
Nov 28 2012, 06:40 PM
So you think an owner of an orignal factory mold it going to let you borrow it so you can pull your 908/914 wannabe out of it?
$10,000 for the front clip maybe.
914GTSTI
Nov 28 2012, 06:49 PM
So,this person you know has a "Factory Mold" ? Or a copy of a OEM front clip he made a mold from?
QUOTE(URY914 @ Nov 28 2012, 05:40 PM)
Eddie914
Nov 28 2012, 07:08 PM
914GTSTI
Nov 28 2012, 07:24 PM
Thanks for the lead. But the 908-3 is it for me.
Randy
Series9
Nov 28 2012, 08:46 PM
.......or maybe we could stop trying to turn a 914 into another Porsche and just respect it for the PORSCHE IT IS.
So many of these cars have been hacked to pieces trying to make them look like something else. Are you not here because you're a 914 guy?
If you want a 908, then save up and buy one. Leave your poor, increasingly-rare 914 alone....please.
914GTSTI
Nov 28 2012, 08:57 PM
Ok!
But your car is stock?
Series9
Nov 29 2012, 07:38 AM
QUOTE(914GTSTI @ Nov 28 2012, 09:57 PM)
Ok!
Not at all. Everyone knows that I modify the shit out of 914s. However, at the heart of every project I do is a 914, and I don't try to obfuscate its heritage.
In the end, it's obviously your decision to make. I'm merely pointing out that these cars are becoming more rare. As I get older, I find myself less inclined to do something totally radical with a still-viable chassis.
There are certainly some who think I'm screwing up cars that could be returned to totally stock /4 status. We all have our lines. Mechanically, I will only use Porsche/Audi/VW engines and parts. Why? That's just what feels right to me.
And aesthetically, I want my cars to look like 914s so the 911 guys will have no doubt from whom the spanking came.
Have fun with your project.
Cohibra45
Nov 29 2012, 07:49 AM
QUOTE(Series9 @ Nov 29 2012, 08:38 AM)
Ok!
Joe,
'obfuscate' and 'aesthetically'..........WOW, not only a great wrench, but great command of the English language!!!
Read a lot as a kid???
Just pulling your leg!!!
jpnovak
Nov 30 2012, 12:28 PM
I know of a 914 based rebody here in TX. Fairly accurate. I am building the engine for it early next year.
It is not the short 908/3. But the longer 908/2. Like this.
I personally like the 908/3. What a car that must have been to drive in anger. So light. So nimble. So fast.
914GTSTI
Nov 30 2012, 01:12 PM
Thanks for posting the photo,jpnovak. This makes me want to keep thinking about it.
914GTSTI
Dec 3 2012, 08:11 PM
I have put the 2 914 back into storage and have goin back to work on my tube/908-3. Thanks for the input on my 914's. Randy
sixnotfour
Dec 3 2012, 09:08 PM
A 908 with a subaroo engine ??
914GTSTI
Dec 3 2012, 10:51 PM
Yep. About the same power and a lot cheeper.
carr914
Dec 4 2012, 07:49 AM
You lost me on that one
