QUOTE(Dave_Darling @ Nov 25 2012, 08:05 PM)
In a stock 914, solid brown wires are always ground. Always.
I see a couple of brown/white wires in the 71 wiring diagram. The brake warning light uses some of them; one goes to the master cylinder switch, and the other goes to the button under the handbrake handle.
One goes from the steering column switches to the horn, providing the ground path for the horn itself. (Note this is different from the later cars, which use a relay for the horn.)
There is also one that terminates at nothing, and is labeled "Sportomatic (optional)".
Those are the only brown/white wires I see on the diagram. Which doesn't mean that there can't be others, of course...
--DD
Hi Dave - thanks for the information - I too see the sportomatic option...thanks again for the help, I appreciate it.
Reg
