jimkelly
Nov 29 2012, 10:51 AM
do the clips simply hold the trim in place by squeezing the trim betwen the clip and the windshisld frame?
seems the clips are plastic? are they held in the the butyl bead?
sfrenck
Nov 29 2012, 10:56 AM
There are plastic pins that hold the plastic clips to the windshield frame (window needs to be out to replace a clip).
Clip hooks onto the turned edge of the trim - doesn't press the trim against the frame (well it does, but that isn't the method that holds the trim in).
McMark
Nov 29 2012, 11:47 AM
They're essentially a fancy rivet. Push the forked piece into the steel (there're holes) then push the pin into place which stops the forked pieces from re-compressing.
jimkelly
Nov 29 2012, 12:02 PM
thanks guys.
heat gun comes in handy again, as my butyl was a mess and in some areas sylicon was used, so i removed it all with heat gun to see if there was a hidden rust issue. i plan to remove the windshield, maybe the piano wire way or some other tool?
correction...
seems there are 19 clips that hold the trim in place.
6 on top, 7 on bottom, 3 on each side.
jim_hoyland
Nov 29 2012, 12:11 PM
After painting and installing new clips, rust began appearing behind the chrome trim where each clip was installed . Turned out the clips were a tight fit and wore the primer and paint away exposing the holes to moisture. UGH
ConeDodger
Nov 29 2012, 12:12 PM
I used an Exacto knife slipped in between the windshield flange and the clip to remove the old. Then, I used a Dremel with a abrasive buff to remove the old butyl. After that, I carefully masked and primed it with rattle can primer sealer. No need to repaint in body color as this is all covered.
jimkelly
Nov 29 2012, 12:25 PM
JawjaPorsche
Nov 29 2012, 01:16 PM
According to 914Rubber, there are 19 clips which they sell:
http://shop.914rubber.com/914-Windshield-t...on-914WSCRC.htmI got them in case my windshleld repairmen needed them when he replaced my windshield but he was able to use the old clips. I returned the new clips to Mark for a refund.
Drums66
Nov 29 2012, 02:26 PM
......And, and the clips should never be reused! or your going to have
problems?
as you were!
JawjaPorsche
Nov 29 2012, 03:19 PM
I don't know anything about windshields and clips. That is why I got an expert who has been in business for 25 years to do it. I got new clips for him and he said the old ones were fine so I am taking him at his word. I know he will make it good if I have problems.
QUOTE(Drums66 @ Nov 29 2012, 03:26 PM)
problems?
as you were!
jimkelly
Nov 30 2012, 06:23 AM
correction -- 19 clips -- see pic above
