QUOTE(LCOX @ Nov 30 2012, 10:15 AM)
Can I use a 2.0 crank and rods with a 1.8 case. Thanx! L
Yes. If you then use OE 94mm pistons and cylinders you have a 2 liter engine. If you use the 1.8 heads, you have what is effectively a VW bus engine (watch the C/R! with those heads!). If you use 96 mm pistons, the ones made for a 2 liter crank, you have a 2056 or something like that. You'll have to be careful about the deck height as the compression ratio goes up as the bore increases.
The Cap'n
