jeffdon
Dec 1 2012, 03:08 PM
The paper on my phenolic spacers is kinda munged up. Would it be ok to take that layer off, smooth them up with some sandpaper, and seal with a gasket eliminator? I have both permatex form-a-gasket and loctite 518 on the shelf. Which would be better?
r_towle
Dec 1 2012, 03:45 PM
I always use some liquid gasket there for the FI systems.
Rich
Cap'n Krusty
Dec 1 2012, 04:18 PM
A thin layer of "The Right Stuff" would probably suffice. My money's on replacing them, but that may not be convenient for you.
The Cap'n
flash914
Dec 1 2012, 05:35 PM
Not a hi jack of the thread ... but I read some where the the angle is and they need to be beveled or they leak. If any one has this experance please chime in Thanks. Gordon
Dave_Darling
Dec 1 2012, 06:22 PM
I don't know of any angle, but the surfaces they seal to should probably be flat. It's not that hard to put the end of the intake tubes on a flat surface and sand it a bit to make sure it is actually flat...
--DD
Spoke
Dec 1 2012, 06:34 PM
I made my own paper gaskets using the spacers as the template. I bolted the spacers together with paper between and just cut out with a razor knife. Took about 15 minutes.
