Little background
Tranny was from donor car so I had never actually driven it yet, supposedly had all new seals in it (and they did look new and clean)
When I filled tranny (first time I've done this sort of thing) the car was ass high. The back was about 38" up and the front was only about 10" raised.
I think I put about 3 or more qts in her so I figure all the fluid went forward in the case. When the car was back on the ground I thought better of it and opened the filler but nothing came out.
After first run with new motor (which is putting about double the stock horsepower) there was tranny fluid everywhere. Got thrown about the motor bay and puddled under the car. The are near the clutch fork looked really wet so I figured it was the input shaft seal or from the breather vent.
I wiped everything clean and after my second race, still more fluid leaking and puddling under the car. Even when I went for a short test drive back home, it was still leaking.
So now I am ready to drop the tranny but figure I'll look in the filler just for the hell of it and the damn thing is full up, right at the bottom level of the port.
So was the tranny just purging the extra fluid all this time? I could peak in the bellhousing near the clutch fork and see a puddle in there at the bottom. Should I just soak up that area, brake clean the case and see what happens?
I am really suprised it is not totally empty.
thanks
