QUOTE(r_towle @ Jan 2 2013, 12:15 PM)
QUOTE(rmital @ Jan 2 2013, 09:39 AM)
::UPDATE::
Got the car running great with a 011 distributor (purchase from dANNY hUNter
Able to time it properly with the cool accelerator bracket from ThePaintedMan (George)
So timing and dwell where it should be.
Excellent pick up off the line. Good advance thru high rpms.
Getting some grumbling/mild-backfire/stumbling thru the carb(s) at full load.
This is new. Didn't happen with the 009...but probably wasn't getting full throttle and same performance at the high end.
Played with the mixture screw(s) some and now it's negligible.
Learning about carbs, so every move/adjustment is a new experience.
question...what would make the carbs stumble/grumble at full load????
any advice is welcomeWhat does the timing look like at full throttle?
A) is it consistant? Use a light, and a dwell meter to see if its steady
b) is it to far advanced or not enough?
If you have a wavering timing and dwell at full throttle, its back to the distributor.
Elec points will solve this problem because they use an optical sensor that does not get effected by a wobbly distributor shaft.
Also, what type of rotor are you using?
Rev limiting rotors can act funky at higher rpms...try another rotor.
Finally, bucking at WOT may be a lean condition due to air getting in via the manifolds, heads etc....spray some unlighted propane around the joints while it running...you will hear the difference.
You can also use carb cleaner or ether...or water...
Anything that can be misted will change the tone when it gets sucked into a crack.
You may need to choose a compromise to get it right.
I would suggest you stay under 30 degrees full advance.
Rich
...thanks Rich. You certainly got me thinking about the distributor's "sealing ring". I replaced the one that came with it, couldn't get dam thing back in. Put a good older one on and it slipped right in. Having a hard time finding new ones on line. I guess I have to go thru Porsche?
also, this is a low budget project..not wanting to spend too much cash on pertronic or similar. Maybe once driving it for some time and the engine holding up well, I'll start to add more stuff.
and you made another excellent point without being there. I really advance the timing according to a tech article on the Pelican board. I might have been a little over zealous with advancing. Maybe back it down to below 30 degress.
it's not bucking at full throttle, just get a little throaty. Could hear of feel it behave differently or not the way it should.
it's a world of difference with my mediocre linkage and stock dizzy...from where I was with the single progressive carb and the 009.
I get that "yeeehaaaw" feeling when I'm driving it around my neighborhood.
now I just have to buckle down and finish all the paper work for the title...
I think it would be easier to title a stolen Honda Civic and make it a daily driver
