It makes a job much easier when you know what you are doing! I am going replace my sail vinyl and I need to remove the trim molding.
Looking the Roll Bar Trim Molding, there a phillips head screw at the top. (I think I can figure that out!)
I found a picture of the Roll Bar Trim Molding. Looking at the picture there seems to be a channel at the bottom. Do you remove the screw at the top then slide the molding out at the bottom backwards toward the rear?
Any help, needless to say, will be greatly appreciated!
