Found out why my motor won't run correctly, spitting out the intake....
valves were tight on this cylinder...
took off the rocker shaft to replace an O-ring...rockers won't move on the shaft????
Turns out the rockers are galled to the shaft!!!!
So for sure this was holding the intake valve open....
anyone have a set of rocker shafts? at a minimum I need 1 shaft and 2 rockers...I am running swivel feet so need a 1.7? rocker???
If anyone has a complete set of 8 I will take them all...please contact me ASAP so I can get this monster running....
PM or email to hberwald@stonyfield.com...if you want, you can call to 603.370.1467.
thanks!
