First of all thank you very much all of you!
I do have both books and worked on 911 engines befor just never a complete rebuild or even build. My experience so far are type 4 engines taught by Jerry.
The 911 is a German import. It is a 72 911 T and it seems to have matching numbers,
but with that being said the car is not an "original stock" car.
It was build and then build again by some small shop in Germany under contract of the previous owners less than perfect.
For example: Front and rear bumper are original Porsche 2.7 RS fiberglas parts, as well as the front bumper. The car had at least 3 different colors and the best part about the 72 the outside oil filler has been moved to the inside and welded closed.
Also the engine must have some upgrades, it used to run better then a stock T.
But I wont know what till I actually take it apart.
The reason for a rebuild are sudden timing chain rattling, worn carbs and bearing shavings I found in the last oil change
My dad loves the old "R" and "ST" Factory Cars so thats why we are thinking about the 2.5.
Also the car is a daily driver, to work or cross country trip, sunshine or snow, as well as mountain races...
