p914
Nov 6 2004, 08:00 PM
I just had my alternator go out . In addition my dash light didn't work and it is part of the circuit for the charging system to work..
Anybody else heard of this?
Carlitos Way
Nov 6 2004, 08:03 PM
We had a similar situation with my parents Tempo (their choice, not mine), about 10 years ago. 3 different dealerships looked at it, and it wasn't until we escalated it to Ford's customer service that they finally found the problem... 3 alternators later, within 2 years.
TheCabinetmaker
Nov 6 2004, 08:07 PM
yep, light no work, no charge.
Nov 6 2004, 08:18 PM
QUOTE(vsg914 @ Nov 6 2004, 07:07 PM)
Joe Ricard
Nov 6 2004, 08:24 PM
Technically the light is required to supply the excitation voltage to the Alt. field winding. You could do it with a resistor but that would be dumb. my 928 had a resistor in parallel to the bulb incase the bulb burned out.
p914
Nov 6 2004, 11:25 PM
QUOTE(Joe Ricard @ Nov 6 2004, 06:24 PM)
That's what my mechanic said too. He explained the entire process. Funy that a dash light would serve dual function.
jim_hoyland
May 21 2016, 08:09 PM
Rich at WCR: several thread address this. Hope it helps...
timothy_nd28
May 21 2016, 08:19 PM
Replace that light with an LED, and the alternator will quit working too
ssuperflyoldguy
May 21 2016, 09:56 PM
QUOTE(timothy_nd28 @ May 21 2016, 07:19 PM)
Had an open amp gauge that caused mechanic to change alternator, jumped around it & started charging
r_towle
May 21 2016, 10:12 PM
Yes
EdwardBlume
May 22 2016, 08:13 AM
How can you test the connection to the alt gen light? If the light is on and stays on, then its the generator right?
jim_hoyland
May 22 2016, 08:21 AM
QUOTE(RobW @ May 22 2016, 07:13 AM)
Right. When the ignition is turned to on and the light doesn't come on was the problem. The test for this is whether the alt light is getting 12v or not; if there is power and no light then the bulb must be replaced.
EdwardBlume
May 22 2016, 08:28 AM
Thanks. I guess I still need to change my alternator.
brant
May 22 2016, 09:13 AM
QUOTE(vsg914 @ Nov 6 2004, 08:07 PM)
jim_hoyland
May 22 2016, 10:09 AM
Question: Is the alt light bulb the same as the oil light bulb ?
Dave_Darling
May 22 2016, 11:34 AM
Same kind and voltage.
BTW, if the voltage regulator is not plugged in, you won't get an alternator light and the alternator won't charge. Don't ask how I know that...
--DD
jim_hoyland
May 22 2016, 12:37 PM
QUOTE(Dave_Darling @ May 22 2016, 10:34 AM)
--DD
Will the alternator light work if the VR is bad ?
Dave_Darling
May 22 2016, 09:29 PM
Depends on what has gone bad in it.
--DD
mbseto
May 23 2016, 11:31 AM
QUOTE(p914 @ Nov 7 2004, 01:25 AM)
[mal]function, seems like... so is there also a fuse in the circuit?
worn
May 23 2016, 11:38 AM
QUOTE(p914 @ Nov 6 2004, 06:00 PM)
Yep. Also you need a two watt bulb or more to get the alternator stated. If you look at the wiring diagram it is one of those clever engineering feats in which the gen light is initially used to bootstrap the windings on the alternator. The way they set it up it warns you of more than one problem using no electronics - just a 2 watt bulb!
rhodyguy
May 25 2016, 10:57 AM
Yes. Generally 'does the red light illuminate when the key is turned to the first position?' Is the first ? asked with charging issues. Generally......but not always.
7TPorsh
Sep 19 2016, 08:29 PM
Bumping an older thread here....
If there in alt light (missing) will alt charge? I see a bare blue wire behind the gauge....must have disconnected from whatever it was connected to.
WHat can I tie it to if there is no light?
Car was charging and now not....
timothy_nd28
Sep 19 2016, 09:02 PM
I'm confused
Why not just reattach the wire? The alternator needs the lamp or resistor, something for it to start charging.
7TPorsh
Sep 19 2016, 09:27 PM
Here's the mess I'm looking at....turns out the loose blue wire was just extra.....in the pic is the alt light in the wrong socket? Look like i'm short somewhere....the ebrake light works.
7TPorsh
Sep 19 2016, 09:33 PM
Also interestingly, the alternator hums now when I didnt notice it before....is that normal? Hum stops when I unplug the VR. Is alt going bad?
timothy_nd28
Sep 19 2016, 09:40 PM
Click to view attachment Two bulbs in the wrong socket locations
7TPorsh
Sep 19 2016, 09:54 PM
This helps....there should be another bulb next to#3 on combo gauge ?? the open hole
Looks like this now
timothy_nd28
Sep 20 2016, 06:54 AM
Closer, but you still have the oil lamp and gen lamp switched.
