I'll start by saying I don't put much effort into setup since many
years ago. But, gotta find out why the last autocross I was mostly
lighting up my right front.
Areas of interest I think:
Brakes
Shocks
Corner weights
Background:
914-6
front = 21mm torsion bar, koni adj (full soft), small sway bar almost full soft
rear = 180lb spring, bilstein non-adj, no rear bar
tires = kumho 215/40/16 all around
I checked on the street with the street tires and it still will lock up the
right front first, if I let go of the wheel it pulls left.
I quickly put the front on the scales with and without sway bar connected
and didn't get significant change from what it was years ago. I'm
reading about 590LF 535RF with driver weight. Had about 50 pounds
difference back when corners were really set, back in the day.
Should I try bleeding the brakes?
Koni adjustables are 10 years old, should I find someone with a shock
dyno?
Thanks,
Mark S.
