I have 5/8 spacers under the rack of my 911 front end but I would like to take them out and raise the spindles on the strut body. I have 7x16 911 offset fuchs.
I have the proper rod ends, 12m 12.9 bolts, spacers and lower support .
I started taking the front end apart and found that I have Boge Struts. The ones with the bulge that prevents the spindle from simply sliding up after drilling out the weld.
I understand the Boge spindles can still be raised, with a little more effort. My question is how?
I read something about cutting off the top and moving it to the bottom. Seems better to bore out the top of the spindle. What is the most common, best method?
