Mike D.
Nov 7 2004, 05:21 PM
I have a webber carbed 2.2. It is making a strange chirping sound under load/exceleration. (not a valve clatter noise) At first I thought it might be the dist. I oiled it and even swapped it out. Then maybe the belt, but why would a belt only make noise under load. Obviously, it is hard to tell exactly where the noise is coming from because it is hard to get your head in the engine bay while under exceleration.
Any idea?
Any Six gurus in Santa Clarita, want to come over for a drive?
Puzzled,
Mike D.
brp914
Nov 7 2004, 05:44 PM
'Course! every neighborhood has a -6 guru! But as it turns out, I am in Canyon Country. I haven't seen another 6 in ages, although I did see one of those new $400+ K GT's on the 405 a couple weeks ago. Anyway, its your alt belt. Spray on a little WD and see if it doesn't go away (temporarily). Get yourself a new belt. Spin that alt while the belt is off to make sure bearings arent bad. Maybe need to transfer shim from inner to outer. Not too loose - not too tight - just right.
You think you got problems, I gotta rename mine the Valdez. New motor in the works though.
Brad Roberts
Nov 7 2004, 05:48 PM
Manifold to carb gaskets. Dells do it... Webers do it also.
Might be the alt belt... but I have heard sixes make the carb "chirp" also.
B
DJsRepS
Nov 7 2004, 06:13 PM
could be an intake leak, exaust at the head, or worse a compression leak eg head gasket hope you find it!
IronHillRestorations
Nov 7 2004, 06:54 PM
It could be pinging. Check your timing and make sure it's dead on the nuts. Also make sure that your plug wires are correctly installed on the distributor.
Joe Bob
Nov 7 2004, 07:05 PM
What size six? I had a 3.0 in one and it sounded like a bike with a playing card in the spokes....ended up being a couple of broken head studs....
Eric_Shea
Nov 7 2004, 07:06 PM
Alternator. My 911 would do it in cold weather starts under load.
(my advice could be a load as well...)
