kmwvmarip
Dec 19 2012, 01:08 PM
Dumb question, again....
Trying to bleed the brakes.
Borrowed a pressure bleeder from a buddy.
All set to go. Then noticed that--duh!--fluid is running out of the overflow tube all over the garage floor.
Would still like to use the pressure bleeder since I am solo... any work around with this. I thought of crimping the overflow tube with "something" but it seems pretty old and crispy. I just dont want to have to replace something after I fry it.
Am I back to the old "pump brakes" option?
Krieger
Dec 19 2012, 01:14 PM
Put a short piece of hose that you can plug on the nipple. Put a clamp on it. Put a cruddy rag around everything in case it pops off.
Elliot Cannon
Dec 19 2012, 01:21 PM
Buy some speed bleeders. They're cheap and make it a one man job.
ruby914
Dec 19 2012, 06:10 PM
That fluid is going to eat your paint, if you don't get it all cleaned off.
stugray
Dec 19 2012, 06:13 PM
Wait.... there is an overflow drain??
I tried the pressure method because I had an extra cap laying around.
I put ~10-15 PSI on the resivoir and it held pressure but didnt help the bleeding at all. If there is an overflow, then it should not have held pressure?
So I went with the speed bleeders. They work great.
Stu
kmwvmarip
Dec 19 2012, 09:57 PM
I checked the tube from the brake fluid reservoir and being 40+ years old, it is just too crispy even to pry it off. Even checking to see if it was feasible seemed not so good as I can imagine cracking the reservoir or some dumb thing and then having a real problem on my hands.
I think I'll attack the problem by pumping tomorrow. As far as speed bleeders--I just don't want to buy one more thing. Shoestring budget and all.
With the glass half full: Guess I'll spend some quality time with my wife tomorrow!
Dec 19 2012, 10:07 PM
After a MC replacement, I had my wife pump brakes while I worked the bleeders. Took no time at all. Drove the car for a while and now I plan to bleed the brakes again just to get any remaining air that may have worked it's way through.
Mikey914
Dec 19 2012, 11:03 PM
I had this problem today. The overflow was pretty crunchy too. I plugged it and proceeded to bleed in sequence. Only problem is that with a new master (19mm), the pedal still softer than a remember it should be.
larryM
Dec 19 2012, 11:15 PM
yup
- that's significant problem with the pressure bleeder Pelican et al sell
you have to plug the overflow - or it won't work
enuf said
