Chris H.
Dec 19 2012, 04:33 PM
I'm doing a 3.3L Subie conversion with a WRX trans using Ian's kit. Not sure the 90 lb rear springs are going to cut it, and they need to be changed anyway. What spring rate would be best? 250 hpish flat 6. Weighs about 350 lbs I think. Don't want my teeth rattled out, just want them to be strong enough for the job. Maybe the stock springs are OK I just don't know.
Build thread coming soon!~
wingnut86
Dec 19 2012, 04:38 PM
Chris,
I'm only looking at a 2.5L SOHC Subie with Ian's setup, and I'm seriously rethinking going back up to 140LB springs from the 90s I currently have.
I'm searching for a spring rate calculator now, but share what you find on your end if you come across one that satisfies our setups.
Dave
TravisNeff
Dec 19 2012, 05:02 PM
What do you have in the front, torsion bar size and sway bar? if so, what size?
Chris H.
Dec 19 2012, 06:21 PM
Travis,
Stock setup now... not even a sway bar but plan to look for a later 911 front suspension with sway bar built in. I had planned to do a much smaller conversion (2.2) but the SVX came up cheap and I couldn't pass it up.
Dave,
I'll definitely let you know what I learn as well. I thought the 140# springs were hard to come by but maybe thats not right.
Mike Bellis
Dec 19 2012, 06:25 PM
I have 200lb progressive springs on mine. From the heavy V8 to the lightweight rotary. I love it. I have not driven with the Audi motor yet.
mittelmotor
Dec 20 2012, 02:00 AM
I think 200-lb. springs would be nice, paired with 21-mm torsion bars up front. That's my setup with the LS1 V-8, about the same weight as yours. I've get Koni yellows set on full soft, and the ride remains pretty civilized, and I've yet to bottom out the rear suspension even at a slightly lower-than-stock ride height.
--Doug
Van914
Dec 20 2012, 05:59 AM
When I did my 3.0 conversion I used:
21 mm Torson Bars
19mm Sway Bar
180lb rear springs
Koni Yellows
Tarrett Polly Bronse Bushings
Van914@aol.com
TravisNeff
Dec 20 2012, 10:40 AM
I would suggest for a decent ride and improved performance, add in a stock or 19mm front sway bar and 140lb rear springs. If your shocks are shot, replacing those while you are at it.
At 350lbs for the engine you are not much heavier than a stock, plus you will be adding some weight up front with the cooling system.
jimkelly
Dec 20 2012, 02:28 PM
i think i've read one say that a rear sway bar feels like an increase in spring rate.
these look nice
http://www.ground-control-store.com/produc...hp/II=76/CA=217
andys
Dec 20 2012, 03:36 PM
QUOTE(jimkelly @ Dec 20 2012, 01:28 PM)
these look nice
http://www.ground-control-store.com/produc...hp/II=76/CA=217Those Ground Control springs and perches are a good value for the money. I have a set on my car. 200# springs on a V8 conversion.
Andys
Chris H.
Dec 20 2012, 04:33 PM
Thanks guys! Great advice. Those Ground Controls look like the ticket. Definitely going with new shocks and struts as well. The rears are coughcoughcough..oldKYBs...coughcough... So I imagine the ride will be much smoother regardless. I assume the Boges up front are original.
nsyr
Dec 20 2012, 06:13 PM
I have the svx engine with suby trans.
initially i had 165# progressive rate on bilstein hd and i had issues with tire rub.
I then put on 185# progressive and it is holding up.
i do plan on putting on collars and trying the 165s again. They just had a more comfortable ride.
nsyr
Dec 20 2012, 06:16 PM
Double post
