I don't think I have a pcv valve on my 2.0 djet . Are we using them and who sells them?
gunny
Dec 21 2012, 07:25 AM
QUOTE(914itis @ Dec 21 2012, 01:06 AM)
I was wondering the same this. I have a 1976 2.0 DJet with no Pcv. Last night I was checking all of my sensors for correct resistance, voltage and ability to hold a vacuum when I noticed that I do not have a Pvc valve. Is this normal for a 1976? My hose runs from the Oil fill cover to the side of my air cleaner box so it doesn't affect the vacuum.
SLITS
Dec 21 2012, 07:57 AM
Your PCV valve is on the oil filler .... it's the thingy on the oil filler where the hose connects to the plenum via the "stacked elbow".
That said, most are connected to the air cleaner (not stock).
76-914
Dec 21 2012, 09:22 AM
QUOTE(SLITS @ Dec 21 2012, 05:57 AM)
at the risk of embarrassing myself by questioning one of our Oracles, I don't think the 75-76 used the stacked elbow.
76-914
Dec 21 2012, 09:26 AM
That's a damned good question. I lucked out and found an NOS one but I had the same question as you before that. Is there an inline one that could be substituted? There must be different sizes depending upon the engine.
SLITS
Dec 21 2012, 09:57 AM
I don't do '75 or '76 and can't remember
The L-Jet doesn't .. it's just a big hole in the oil filler.
Early has mesh underneath that acts like a valve ...
'73 - '74 has a wafer in the hole .. can't remember if it is spring loaded.
I am unable to look at any parts as I am floating in space due to gravity reversal
And I could be totally wrong .... not the first time, but certainly the last as the world has ended ............................................................
914Sixer
Dec 21 2012, 06:34 PM
PCV valve is in the oil filler tube on the 73,74 D Jet. I do not know about the 75-76 because of the air injection plumbing. See pictures
tod914
Dec 21 2012, 06:36 PM
No pcv on the 75 76 2.0s. Sometimes you can get alittle blow back into the air filter being it does not have one.
