CG-914
Dec 24 2012, 10:38 AM
Hey everybody,
this morning I got the greatest Christmas present ever from my girlfriend.
A Lincoln E. Welder. Modell: Work Pak 125.
As far as I know Lincoln is one of the best companies with Miller, Howard.
I know the power is plenty for car sheet metal.
I am unexperienced welder
no, no experience at all.
So I have a few questions:
- The welder does not come with a gas shield, do I need one for welding Porsches?
- Could I equip the welder with gas?
- What else should I know?
C
PanelBilly
Dec 24 2012, 11:14 AM
They have a kit to add the gas. I got mine at Home Depot years ago, but I'm sure they still stock this stuff. Ge tthe tank from the local supplier of gas.
Get some clamps. As you weld, it pushes the material apart.
Your in for some fun.
SLITS
Dec 24 2012, 11:16 AM
Here's your conversion kit from Home Depot ........
Gas ConversionClick to view attachment
d914
Dec 24 2012, 11:17 AM
Lincoln Electric MIG Conversion Kit with 1/4 in. Regulator with Gauge Model # K2526-1
Internet # 100672827
Store SKU #
Store SO SKU #
Overall rating 4.1 / 5 Rating breakdown 12 reviews
5 stars74 stars23 stars12 stars11 star1Ease of installation
4 / 5
Quality
3.3 / 5
Value
3.1 / 5
8 out of 11(73%)reviewers recommend this product.(12) Write a Review Share this product Questions & Answers
Ask a Question Question Questions, Answer Answers| Read All Q&A | Ask a Question
$121.00 /EA-Each
WAS $121.00
pilothyer
Dec 24 2012, 11:29 AM
You will definitely want to get the MIG conversion kit # K2526-1 for your new welder. You will need a tank of gas as well( 25/75 argon/co2) You can practice with the supplied flux core wire just to get a feel for things but when that runs out you should stick with the best solid core you can get. You will probably find that 25 - 26 wire will be the best for sheet metal work. Also you will want a good automatic helmet......that hand held unit is good for spectators.
Also you should try to hang on to that girlfriend.
mrbubblehead
Dec 24 2012, 02:41 PM
and as far as not knowing how to weld, lots of city colleges and adult education schools offer welding classes pretty cheap. and totally worth while. learn the basics first....
laflaur
Dec 24 2012, 03:12 PM
you guys are slipping..
Cool gift,pics of the gf please
pilothyer
Dec 24 2012, 05:33 PM
I've met her before and all I'll disclose at this time is that she is a Gorgeous Redhead
GeorgeRud
Dec 24 2012, 06:19 PM
I'll second the suggestion to find some classes at the local community college if possible. They'll help guide you through the steps to become proficient and safe.
You'll find that it's also a lot of fun!
Merry Xmas, keep that girl!
L73
Dec 24 2012, 08:46 PM
U tude mig welding on sheet metal.... Great tips out there
patssle
Dec 24 2012, 09:59 PM
Welding releases toxic stuff you shouldn't breathe...sometimes it's even cancerous (such as Hexavalent Chromium from stainless steel welding). Make sure wherever you are welding is properly ventilated.
CG-914
Dec 24 2012, 10:24 PM
thank you all guys!
Yes she is a gorgeous redhead!
But she said no pic and how could I say no today?
I will defiantly go with the kit
and look into some lessons if affordable
Merry christmas too you all!
How is that actually with the four power settings a,b,c,d is that enough or should it be without steps?
Let me know what you guys found in your stuffing!
Socalandy
Dec 25 2012, 12:40 AM
It's a great little welder and the MIG kit is a must and easy to install, As for the A,B,C,D settings if you flip open the side cover you'll see the Metal gauge and wire guide. You might want to order the cart too, Store's everything and holds your gas bottle
I got the recommendation to run a CO2/Argon gas mix and it works awesome
rfuerst911sc
Dec 25 2012, 05:20 AM
Welding is one of those things where practice is the key. You have to develop a " feel ", if you don't your either just globbing on metal or burning holes ! For us DIYers it's a little harder because we are not pros and for many of us a lot of time passes between welding sessions. But once you have the feel for it you can weld quite well. For finish work you want to use shielding gas, for working outside go with flux core. A good auto tinting face shield is a must ! And full length leather welding gloves come in handy. A few welding magnets come in handy for holding the pieces you are welding. A brass brush, extra tips and tip cleaner. Have fun.
Razorbobsr
Dec 25 2012, 07:57 AM
QUOTE(CG-914 @ Dec 24 2012, 11:38 AM)
Hey everybody,
You need to get that gal ' Under the Hood' ..... she is a winner!
C
Trekkor
Dec 25 2012, 03:22 PM
I have had fantastic results with this same set-up.
I use straight C02 gas and it produces great results.
KT
r_towle
Dec 25 2012, 04:36 PM
Seriously, pics of the gf
CG-914
Dec 26 2012, 02:27 PM
Talked to Lincoln today because there is more then that one kit...
They told me the new 125's would not be able to be converted anymore...
Trekkor
Dec 26 2012, 02:38 PM
Return the welder for a unit that can utilize gas.
With flux core only you will be limiting yourself.
KT
CG-914
Dec 26 2012, 02:42 PM
Here is a pic is it still cinvertable to mig?
Trekkor
Dec 26 2012, 02:47 PM
If it is convertible, it will have an inlet for the shielding gas on the back near the power cord.
You should also see settings inside the flip up access panel for BOTH gas and flux core welding.
If it doesn't have these, not convertible.
KT
CG-914
Dec 26 2012, 03:08 PM
sadly no and no to both points!
Also talked to another guy at Lincoln and he found out that I would not be able to get all the parts separate to convert it!
CG-914
Dec 26 2012, 03:19 PM
Lets raise the question what is better Lincoln, Miller or Hobart?
I guess a 140 model from ether company is plenty?
Trekkor
Dec 26 2012, 03:24 PM
You will have no trouble with any of those brands.
Determine what you plan to do and buy a slightly heavier duty unit than you think you will need.
KT
