QUOTE(Jeff Bowlsby @ Dec 24 2012, 02:06 PM)
I know what all of those are.
I thnk he wanted help ID'ing them Jeff, not a guessing contest!
L is the knob from a window crank,
middle is the female 1/2 of the seatbelt clip which holds the loose end of the belt, & the other half is u-shaped with clips that go into the slots on each end (IIRC you can still get new clips from vintage VW parts suppliers),
right is the manual opening knob for your headlight & mount on the bit of the threaded shaft that sticks out the back end of the motor.
