SOLD!
1975 Porsche 914 2.0L, $10,500
Zambezi green 1975 2.0L 914, 4752904140
California/Arizona car, originally sold by Wes Lasher Porsche & Audi, Sacramento Calif on 5/31/75. (have invoice and copy of window sticker)
No rust, current odometer reading, 119719 miles (actual)
New clutch/pressure plate/bearing/flywheel @117000 miles.
New tires, including spare.
External oil cooler and thermostat.
Upgraded air conditioning including sanden style compressor, compressor mount, barrier hoses, and updated condenser fan, still uses R12
Upgraded H4 headlamps
New targa top and door seals
Petronix electronic ignition
New Terry clutch cable, shifter bushings
Kenwood stereo with amplifier and speakers.
Optima Red Top Battery
Clutch cable tube repair compelted
New fuel lines
Includes multiple bins of new and used spare parts including original exhaust, smog parts, heat exchangers. Currently have 74 exhaust installed, passes AZ emissions with drop in cat. (parts not available seperatley)
2 car covers and bra, (1 full/1 umbrella)
Valve adjustment/oil (Brad Penn 20/50)/cap&rotor/plugs @118713 miles.
Shift lever has been re-bent to accommodate 6'2 driver, no circus act to shift into first. (original shape shifter included in spares)
Sanden compressor install below engine disables passenger side heat exchanger. Still plenty of heat/defrost available on single HE.
1 2" worn spot on drivers seat, (see pictures)
Spacers on front tires.
