GulleyGulley
Dec 27 2012, 11:26 AM
Current setup is 6:29 short ring & pinion & Quiafe limited slip. I'll be running a 3.2 engine & would like the gearing to be more streetable. Right now it runs about 3 - 4,000rpms at highway speeds with a 2liter six installed. The PO had this setup more for autocross than street use. Most of my driving is highway/street with less than 12 track/autocross events a year. What would you suggest?
r_towle
Dec 27 2012, 11:39 AM
First off, what are you doing with the 2.0 liter motor?
If you want to sell it, please let me know.
For the transmission gearing, I would suggest you go seach through the CarQuip web site.
He has some decent gearing charts.
There is also a few spreadsheets here if you search for them.
Rich
GulleyGulley
Dec 27 2012, 12:41 PM
The 2.0 will be for sale later this winter. I want to hold onto it until I have the 3.2 installed. It's a good, no issue engine. PM your email & I can send you some pics and build info on it. I'm going bigger to keep up with F'ing hondas & mini coopers. They're kickin my poor old car's butt.
Steve
Dec 27 2012, 03:19 PM
With the 901 second gear cannot be changed, so your kind of stuck with first and second. On flat ground I would start off in second with mine and only use first to get the car rolling on steep hills. Regarding 5th, switch to a flipped H. It will make the 3.2 run at 80 mph at 3k rpms.
r_towle
Dec 27 2012, 05:02 PM
you may want to match a 911/915 gearbox.
I have the 3.2 carerra, the gears are great for all types of driving.
Mine is an 84/85 so its a first year 3.2...they changed the tranny later on to the G50, but the 915 gears can be used in the 914.
You can change the 2nd gear pretty easily with a 904 main shaft.
Otto's Venice has them typically..or ebay
Rich
0396
Dec 27 2012, 05:37 PM
QUOTE(r_towle @ Dec 27 2012, 03:02 PM)
Rich
Correction - to my knowledge, you can not use 915 gears in a 901 box
jimkelly
Dec 27 2012, 06:52 PM
i think he meant gear ratio's
Trekkor
Dec 27 2012, 06:58 PM
Get a stock 5th gear set.
I bet someone would give you a set.
I just gave away two.
There is a fair amount of work in doing trans disassembly and gear swapping.
If this is a street car, you may just want to install a good used 901 and sell the racing gearbox.
KT
Trekkor
Dec 27 2012, 07:13 PM
This chart is very important if you are considering running different gearsets in your 901:
My current set is: C-F-Ka ( flipped ZD ) S-X
65 mph in 5th is about 3600 rpms, for example.
7300 in 1st is 45 mph on the other hand.
KT
GulleyGulley
Dec 27 2012, 08:18 PM
Thanks for the chart. Great info to have. I may go as suggested & install a stock type tranny.
Steve
Dec 27 2012, 09:21 PM
I dumped the 901 for a 916, because I didn't want to end up a 4 speed. 1st gear is way to low for a 3.2. You could buy a 904 main shaft and change all the gears to match a late model 915, but you will still end up a with a weak first gear that you will always be paranoid about.
Dr Evil
Dec 27 2012, 09:30 PM
The best gearing all around for a 3.2 is an A, F, O, X, flipped H. Your wheel dia will dictate the the end RPM. You can change the R/P and enjoy the 7:31 stock setup for taller gears.
All this is not too much $$ to do and you can sell the 6:29 for $$$
brant
Dec 27 2012, 11:27 PM
QUOTE(Steve @ Dec 27 2012, 08:21 PM)
I run an F first gear
and 5 useable gear ratios
they are good for 200hp on a race track
more on a street car
some of the weakness myth is just that....
