Have a '74 Single Weber 32/36 electric choke, 1.8 Fresh rebuild with correct Cam for Carb conversion, Pertronics Ignition and Coil, purrs like a kitten.
Problem is on startup runs good but as it warms Idel slowly drops from 1500 to zero killing the engine, restarts immediately but have to feather throttle to keep from dropping off again.
Once it's at normal temp isn't as bad but when I stop with clutch in it drops off to zero rpm unless I'm in neutral clutch out? Push clutch in RPM drops.
Now this gets more interesting, once moving at normal temp shifts between 2nd to 3rd, and 3rd to 4th, clutch in RPM does not drop from where it was. Shifting from 4th to 5th RPM actually slowly increases from where it was when running in forth while not applying throttle until clutch is released?
Same Carb as was on the car before the rebuld and non of these problems occurred prior to the rebuild
Any thoughts or suggestions as to what to look for?
