Full Version: pics of 914 turbo plumbing
mattillac
i was considering aftermarket pefi and a turbo for my
type-4 914, but plumbing the turbo without cutting out the trunk or using really long tubing seems difficult. anyone have a 914 with a turbo?
Joe Bob
ME FIRST....YOU CAN"T TURBO A 914...... <_<
Mueller
if you could really turbo a 914 smile.gif , then you could mount the turbo in the engine compartment and run the exhaust up to it...the easiest would be to have the exhaust come up in front of the engine to the turbo....of all of the turbo's I've seen in 914s, the turbo is place either way in the back near the muffler with the intake tube being real long, or with the turbo mounted in the engine compartment with the exhaust tube being real long....both methods work and unless you are building a car that you need to extract the very last bit of HP out of, pretty much any method is going to work....that is of course if you could turbo a 914 smash.gif
mattillac
well, i'll try both and post my pics when i'm done, in about 3 to 5 years. <_<
Eric_Shea
Check back issues of Excellence for Ed's ride.
nein14
As the current owner of EvilEd's turbo 914 you can turbo a 914 and it's a blast to drive!!!!!!!!!!!!!!!!!!!!! mueba.gif
Eric_Shea
ChrisReale
AirSix also has a Turbo with custom plumbing on his 1.7L
Mueller
QUOTE(nein14 @ Nov 8 2004, 05:51 PM)
iamchappy
Cutting a few holes in the trunk is the easiest, you maybe able to use the existing
holes by removing the seam sealer from around them. The nice thing about running
from the back is that all the pieces can be attached to the crossover pipe and can be
removed in one piece.
Mueller
iamchappy,
from that picture it looks like the turbo "stuff" would hit the pavement going up a steep incline....
URY914
Here is a 914-4 turbo...
URY914
It has been done...
ppickerell
So who wants to talk about designing a easy bolt on T4 turbo installion kit. What's the HP gain? What's the price point that would work?
mattillac
QUOTE(iamchappy @ Nov 8 2004, 05:57 PM)
i think thats the way i'll go when i turbo. i'm signing up for welding and machine shop class tomorrow. monkeydance.gif
iamchappy
I am refabricating the rear crossover pipe to raise it up another 2 inches to help the drain angle on the oil drain. It looks lower than it really is, look at the height of the exhaust pipes.
Here is how a turbo looks in my car.
airsix
QUOTE(Mueller @ Nov 8 2004, 03:02 PM)
Mine is actually somewhere inbetween. My turbo is 1/2 in the engine compartment and 1/2 out. I don't have any decent pictures, but I'll try to draw you a visual image. The turbo is located on the passenger side almost exactly opposite the starter. The rear vertical engine cooling tin piece has been cut and the compressor (cold) side of the turbo peeks into the engine compartment through the hole cut in the tin. The turbine (hot) side of the turbo is outside the engine compartment along side the bellhousing at about the 2:00 possition. The exit side of the compressor points straight back running paralel to the bottom of the trunk with about 2 inches clearance. Oil drainback is gravity feed into the right valve-cover. I used an IHI turbo from a 1.8 Subaru. It seems to be sized well. Boost starts at 2,300rpm and is still pulling when my injectors saturate at around 5,700rpm @12psi. (I'm working on getting some bigger injectors). Not including the PEFI, adding the turbo only cost $175 for everything.
Turbo & all the plumbing: $175
PEFI on the cheap: $500
Pulling away from a late model Impala: Priceless.
Pulling away again when he comes back for more: Priceless^2. happy11.gif
-Ben M.
mattillac
airsix, did you modify your oil pump to help supply the turbo? can you still fit your targa top in there? the car looks great! aktion035.gif
redshift
QUOTE(iamchappy @ Nov 8 2004, 09:57 PM)
Cutting a few holes .....
Dood, that -radio edit- has a big fat -radio edit-!
Pic looks great!
YOU ARE AN EVIL GENIUS!
M
Mueller
QUOTE(ppickerell @ Nov 8 2004, 07:26 PM)
it's the fuel/ignition management that is the killer of this idea...I don't know enough (nor do I care right now) about the stock FI to get it to work properly....once you add on an aftermarket FI, the cost just starts to skyrocket unless you get some of the smart guys like Ben to do thier own fuel systems.......
making the brackets and adapters are no big deal, the tubing if you want custom exhaust will be costly..of course no reason that it just couldn't be based on the stock or SSI heat exchangers like the few that are already up and running...the cost of the turbos vary.....I bought a used turbo similar to Bens for $75, i also have 2 newer more modern rebuilt turbos that I bought for $250 each. I only plan on using one...it's rated for 168hp...I was thinking that when i put everything together for my turbo motor, I'd build/make all the parts in duplicate and sell the 2nd "kit" once my installation was somewhat proven to work..not really looking to make a profit, I just would like to break even smile.gif
iamchappy
I would think you could run with the existing fuel injection system by plumbing in a 5th injector that fires off a hobbs pressure switch, I am running a 7th injector on my six with great results, A MSD BTM ignition will handle the timing. I am barely retarding my ignition because the 7th injector works so well.
I like the keep it simple idea first, and move on if more is work needed. I think a type 4 engine would be a fun project to turbo on the inexpensive side with great results.
Bruce Allert
If someone would make a pictorial installation guide I think it'd be worth some good bucks. That's the only thing that holds me back from doing a turbo... I don't know anything about it, where to begin or how unsure.gif
.....b
Brad Smith
Ok, I get to chime in with something I know a LITTLE about... woohoo.
To start with, someone said T4... I say that's WAY too much turbo for that itty-bitty flat 4. I'd stick with a moderate sized T3, which has the additional advantage of having the wastegate built into the turbo housing- cheaper, easier to fabricate the system, and more compact. Get them cheap from the salvage yard from a turbo T-bird or Lincoln. Or use the turbo from a late 80's RX-7, again with integral wastegate... but that may be marginally too large, depending on your power "wishes."
Second, a short exhaust and long intake is better than the other way around. You want the turbo as close to the exhaust ports as you can get it, to maximize the energy "felt" by the turbo from the exhaust pulses. It will spool quicker that way. If one were to run a divided inlet turbo with each side getting the pulses from 2 of the cylinders (the opposed ones that fire 360 degrees apart) that would help it spool even quicker, but the plumbing would be a nightmare.
Third, turbos give off a LOT of heat. I suspect having the turbo in the engine compartment of a 914 may give you some cooling grief. Shield it off as much as you can. (note that I didn't say they GENERATE a lot of heat... they generate a LITTLE heat from mechanical friction and by compresing the air, but the housing of the turbo will radiate a lot of exhaust heat.)
Fourth, GET AN INTERCOOLER. 'nuff said. Ok, maybe NOT enough. Cooling the intake charge will both give you a denser intake charge and reduce the heat that is ingested by the engine to begin with. It will make more power and be less subject to detonation.
Brad
Sammy
On mine I built a short header/collector that came up at the right-front side of the tranny where it conected to the turbo. That was as short as I could make the exhaust plumbing. I used a sidedraft weber on top of the engine in a draw through style (not the best but very simple and it worked).
I had the discharge of the turbo plumbed into a modified stock intake manifold.
I wrapped the turbo with muffler insulating wrap and didn't have any heat problems.
Having the turbo lower in the car creates a whole new set of problems for oil drainage but nothing that can't be solved, it just adds to the complexity. I like simple.
Intercoolers don't do squat except create more lag at boost pressures under 6 psi and can't really be justified on a 914 until you get above 7 psi IMO, plus you need to get lots O' air through it, not easy.
Heat of compression is not linear and doesn't really climb much at all for the first few psi, then gradually starts to increase as boost goes up.
Intercoolers work on differential temperature and are not efficient if the air charge is only 15 or 20 degrees hotter than ambient.
iamchappy
An intercooler will be needed if you plan on running 12lbs of boost or more, but significant horse power gains will be seen at 9lbs or less without an intercoooler.
The efficiency rating of a intercooler at low boost is minimal. I suppose if one was trying to extract every bit of horsepower out of an install all the things said about shorter exhaust, exhaust pulses flow and then some would be a factor, but for someone putting together an uncomplicated system that would still provide huge horsepower gains, simple straight forward easy to build designed like what I have done on my turbo 3.0 six will get the job done.
I am sure I am giving up a few horsepower here and there with my install but come take a ride with me and I doubt you will come away with the feeling that I need any extra horses.
Mueller
from what I understand, the stock /4 (D-Jet) has "issues" once the MPS sees positive pressure so just installing an extra injector is not as easy as one would think.....
as for the shortest length exhaust....according to Corky Bell, for a street motor, it's not that big of deal, yes you want all the plumbing to be the shortest as possible, but for a "bolt-on" kit, you'd never know the difference since you are not trying to build the most optimized system for the average person.....I don't see a huge market for this, maybe 2 or 3 people would really be interested and then when it comes time to buy it, they'd be nowhere to be found smile.gif
as for making kits, I think the best way to approach this would be to at least devolop one good running example, take plenty of pictures and make instructions with the drawings and part numbers...not sure how to price it, but obviously it has to be cheap for us 914 people smile.gif
airsix
Here are a few of my thoughts.
Injection: Jenny's brother Jeff ran D-jet on his turbo. As I recall putting boost on the stock MPS broke it eventually. Maybe my memory is wrong, but that's what I recall. Why mess with D-jet when you can go Megasquirt for around $200 total cost and have a programable system designed for forced induction? (Jeff used the D-jet as an experiment)
Intercoolers: True, 914 turbos should have intercoolers. And there should also be world peace, a free Tibet, and a restoration of the rain forests. What I'm trying to say is that I've converted my 914 to a hydraulic clutch, digital fuel injection, crank-fired ignition, and fabbed my own turbo installation.... but I still can't figure out a practical way to install an effective intercooler. I haven't given up, but I'm telling you it's been a challenge for me at least.
-Ben M.
Brad Smith
I can think of SEVERAL ways, but they're not really "easy."
1) 914-6 engine cover, ducting to keep the hot engine air away from the intercooler. This seems the most practical for me... probably need an e-fan to cool it. Short plumbing runs. BTW Supra intercoolers are compact, efficient, and can be had CHEAP on ebay or from the salvage yard... and they don't look like the typical intercooler for you stealth guys.
2) Hack out the trunk and mount it between the taillights. (you could do this and keep some useable trunk space... but it's not very stealthy!)
3) On cars with body kits, mount it in the fenders. (rear quarter panels I should say)
And an intercooler on a draw through setup would allow more chance for the fuel to "settle out" so I would say forget it on that.
4) If you want to get more complex, an air-to-water setup allows you to have the plumbing short on the intake tract but you can put the "radiator" anywhere you want. One of my buds did that with his RX-7. He took the notoriously inefficient (due to size and location) stock 2nd gen RX-7 intercooler and built a water box around it... then plumbed it to a tiny radiator from a civic or geo or something, and plumbed it up with a tiny electric water pump in between. It worked great- he makes 425 hp at the rear wheels with that setup. (with a big honkin' T4 based turbo and some porting on the engine, and a Haltech to manage fuel and ignition.) So how about beside the tranny with a fan directing air? Lots of options folks. This one is a bit more weight, so moving the battery up front would be an idea to mantain balance.
I joined here to learn more about the 914, since I'm looking at getting one for my daughter... but it sounds like you folks are like "gearheads" everywhere- lots of ideas and good info on here. smile.gif
BTW I'm normally a "rotary" guy... hmmm... since I have a turbo rotary motor in the garage, maybe I should put THAT in a 914... nah. Too much power for a 16 year old. laugh.gif
Brad
