jdlmodelt
Dec 27 2012, 10:30 PM
What can I do to my 1972 1.7l to get as much HP as my stock 1976 2.0l?
Tom_T
Dec 28 2012, 12:54 PM
`72 1.7 = 80 HP
`75-76 GC 2.0 = 88 HP
Low budget, medium, high, unlimited?
Going to a freer breathing 2.0 SS Exhaust/HE & Muffler will damn near gain that 10% 8 HP alone! ..& that SS exhaust will last longer than the rest of the car.
Now a 73-74 GA 2.0 is 95 HP (100 with Euro heads), so that's more the transplant that they're talking about. But if you're going to transplant a T4 motor into your 72 /4, then why not for for the gold with either an up-build of your 1.7 to 1.9 or 2056, or a 2.0 built to 2056 - 2270, etc. for 110-145+ HP?
Check McMark/Original Customs, Raby's MassIVe (if he's still messing with 914 motors, or FAT Performance here in Orange CA.
However, if yours is a fairly original & pristine 72 914/4, then I'd stick close to original & only tweak with the 2.0 SS HE's & muffler, saving your 1.7 system for originality if needed by you or future owner.
PS - an aftermarket K&N stock filter in the OE oil bath filter air box, or aftermarket-style snorkel & cone filter, can improve airflow on the intake side too for another few HP, and again the OE oil bath filter/box can be retained for future return to stock OE if pristine. Between the K&N + 2.0 SS HE/exhaust you should easily make or beat another 8 HP.
Chris Pincetich
Dec 28 2012, 01:41 PM
bolt on a good 4->1 header system
It's the best investment I've made to my 1972 1.7L
Next, reduce weight to go/stop faster!
The header usually sheds 10-20 lbs vs. OEM style exhaust and heater components, then get a small battery, remove OEM "sound dampening" from floors, engine bay, and backpad, and then
