QUOTE(jdlmodelt @ Dec 28 2012, 07:15 PM)
any idea how to verify if the po installed the fuel lines according to the above diagram?
I would think only by verifying the sizes of the lines. It may be that you have the CFR SS lines; in his set they are 2 sizes so hopefully the PO installed them correctly. Get under the car and look at the lines. If you're questioning the rubber hose connections between the feed lines and the fuel rail being correct, I don't think the car will run if the fuel lines are reversed; easy mistake to make and one that has been discussed on the World before...
