Full Version: Clutch cable heat protection
1845
Anyone have a line on a clean heat sheild product that you can put around the clutch, accelerator and speedo cables to protect them from the heat exchangers?
JawjaPorsche
The accelerator cable is nowhere near the heat exchangers on my car. My clutch and speedo cables are far enough from the exchangers to not be a problem.
Maybe someone else on this forum thinks a heat shield is needed?
1845
Sorry, should have been more specific, on the 914-6 the 3 cables all run along the same path under HE toward the transmission. The factory didn't put anything on them and clipped them to the HE but thought I saw a wrapped that someone has used.
jimkelly
maybe a cloth exxhaust wrap is all the is needed?
http://www.jegs.com/c/Heat-Shields-Insulat...CFYqZ4Aod_lUAVQ
or this sleeve
http://www.jegs.com/p/JEGS-Performance-Pro...130487/10002/-1
mrbubblehead
this is what i use. i use it on the clutch cable, driver side parking brake cable (which sits on the exhaust) and my fuel lines... http://www.summitracing.com/search?keyword...leave&dds=1
gothspeed
Here is another from McMaster Carr:
http://www.mcmaster.com/#standard-wire-ins...leeving/=ktklsf
