QUOTE(914Eric @ Dec 31 2012, 12:00 PM)
QUOTE(Cap'n Krusty @ Dec 30 2012, 02:42 PM)
There really isn't an official torque setting. Here's the most common technique: Overtighten the nut, then back it off. Tighten it again until you can "just" move the washer side to side with a screwdriver. DO NOT use it to pry the washer, just apply sideways pressure on the on it. It should be somewhat difficult to move; neither too easy nor too hard. After it's locked into place with the 7mm bolt, you should just be able to feel a very slight bit of free play when grasping the top and bottom of the tire and giving it a wiggle.
The Cap'n
John...Huh???
You know I respect your knowledge or I would never have sought you out for private advise as I did.
And I'm not a professional mechanic, but I've done a lot of wrenching in my time and never seen a bolt that didn't have a torque setting. Guess I've been doing it so long that I just tighten to feel depending on the bolt size and application.
But overtighten; loosen; tap with a screwdriver; Wiggle; etc... Sounds like a comedy skit.
Happy New Year John
OK. That's how we did it at Porsche school, that's how I've always seen it done, that's how we do it here at the shop, that's how the brake guy next door always did it. I don' need no stinkin' torque setting. Oh, when was the last time you had your "feel" calibrated? Was it expensive? Did it hurt? BTEW, there a lot of cars on which you overtighten various fasteners, back off, and then torque. Transmission and axle fasteners, mostly.
Happy new year to you, too.
The Cap'n
