ChrisFoley
May 16 2003, 07:27 AM
Kerry Hunter Headers (and others) have a common problem. The little ears that go over the studs bend and make it harder to mount. They also crack the pipe sometimes when you tighten the nuts a little more to get rid of that pesky exhaust leak, making things worse.
ChrisFoley
May 16 2003, 07:30 AM
I can cut those things off and replace them with the machined blocks I use on my stub pipes. You can apply more torque, safely. They line up better with the studs so there is less chance of leaks when torqued carefully.
ChrisFoley
May 16 2003, 07:32 AM
Price: $175, plus shipping
Brad Roberts
May 16 2003, 02:32 PM
The problem I found the most.. people with bent studs. I dont think I have ever ripped any off the stub tube or broken one. Another reason why I use the European racing header (they use a solid piece for the stub tubes also..instead of a bent tab)
B
SPNR
May 17 2003, 05:14 PM
Brad,
Where for you are having to get EUROPEAN RACING HEADERS for a four?
