QUOTE(synthesisdv @ Nov 9 2004, 07:31 PM)
I have heard about the fan rubbing on the shroud after a heavy powdercoat or paint job.
Yep, it is a bit too thick. Not because of the paint, but because of the primer/filler
The fan and housing were in pretty bad shape and it took quite a bit persuading to get a smooth surface
So, it'll have to be done again (I think I'll have the housing done in black chrome)
This was more a "lets see if it works" experiment and I wanted to show the results
The paint is very durable (same as powder coating).
It is also used for wheels (you can mount tires without chipping the paint)
